So I have a 90 supra turbo. I just changed my diff fluid to royal purple and now the lsd does not work. Is there a different fluid that is not so slick that would work bette with my lsd. Thanks everyone
Using 75/90-wt LSD differential carrier oil from Ford motor company makes Supra differentials run quieter and smoother than any other oils tested.
GrimJack;1821857 said:Until I switched to a Cusco rear diff, I always used Ford oil, based on this note from Reg Reimer:
http://www.suprasonic.org/public_html/sonictech/mk3/mk3_pmtn.html
The Ford oil comes in two parts now, the oil itself and a small container of friction modifier that you add. It's cheap, easy to source, and works extremely well.
I had two Supras that were around 135-140,000 miles on each of them and I ran Redline throughout both cars with no issues. But someone did say that with a high mileage Supra, Redline caused a chatter and the Ford oil did not.chris_u_diaz;1822308 said:i also need to change my diff fluid, what would be better Redline 75w90 with the lsd additive or that Ford stuff? its for Supra with 160k miles
