LPPRO's over the top 2jz hybrid build
CTsupra
lppro;1395017 said:
I seriously doubt that, there is no way toyota would sell a complete assembled short block that needs work.
There is also people that say the short blocks come out of mexico! hahah BS
Searched over on SF, and there were a few problems with the blocks years ago. They are corrected now. Some bought new short blocks and the tolerances and clearances were out of spec, another problem experienced was the oil passages were not completely bored.
Though it was very few blocks, I would tear it down and check it if I'm spending that money.
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
update:
so yesterday i got the time to go pick up all my stuff (head, old block, etc)from my friends shop.
and today i got off work early so i decided to tackle the port&polish. i have a whole new respect for people that do this for a living... now i know why it is so expensive!
so yea its gettin there. i still got some work to do on the exhaust side but its nearley done.
heres before and after:
i think it will flow a little better (;
and just a pic i thought was cool,
tomorrow im going to finish the exhaust side and maybe get it down to the machine shop to be decked.
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
IJ.;1394513 said:
Heard quite a few cases of the shift mechanism locking up and the trans having to be opened up to sort it out after being left like that...
I just layed my down just in case...thanks for the info veteran........ :biglaugh:
ippro great build its looking very amazing...
lintlars
ROOTS RADICALS
Ft.St.John BC
IJ.;1394821 said:
I haven't experienced it myself as I've always stored em flat but a few friends have so just figured even if there's a slight chance I'd warn you :)
Ive experienced it not a fun job after you think your done and have to rip it out and tear it apart to manualy disengage the gear
lppro
Apr 21, 2007
895
so i got some of the wiring done today, built a little power distribution and fuse/relay panel to go next to the battery in the trunk. ill post some pics up tomorrow if i get the time.
also should have the mockup block and head in place soon so i can start fitting all the new stuff. maybe ill put my new welder to use! (;
lppro
Apr 21, 2007
895
ok finally got a little more time.
i got the mock up motor in place. i actually had to do it by hand because my cherry picker broke! so i put the just the block and oil pan in first then the head. yea it wasn't the smartest thing to do but i got it done and didnt scratch and paint.
heres what i did so far for wiring up the power for the car,
i have some more goodies coming in the mail to finish that up but you get the idea. when finished everything will be cleaned up and tucked away..
i think im missing some stuff here what do you think? lol
my old rotating assembly serves as a cool decoration for now.
let the mockup begin!
Supra_Villan
needs his car done
Nov 10, 2007
662
Wellsville MO
why so much upgrading and only going with 550's? just curious not dogging i mean if you are going the extra mile (or ten in your case lol) everywhere else then why not there?
lppro
Apr 21, 2007
895
I got all the wiring routed now and have started wiring up all the go-tech stuff. It is supriseingly simple. I am very happy with it so far.
I put a new hole on the intake side in the firewall for most of the harness to go through so it doesn't have to be seen going across the top of the firewall. It is coming out super clean, the only wiring that is going to be visible on the intake side is going to be the injector leads and the TPS wiring.
I took some picks tonight but my camera died and I cant currently find the charger.
Fubar231
402
columbus
This builds looking amazing. Good job lppro. Can't wait to see what it turns into. And on the other note, seems like you really know what your doing, are you a mechanic or something or do you know all this knowledge from this just being a hobby?
lppro
Apr 21, 2007
895
Thanks, my supra is actually the first car I really did any work on mechanically, I bought it when I was 17 (I'm currently 19) and honestly I have learned by trying and by this site. after I did my first swop last year I got a job at a local tuner shop and learned more as I worked there. Now when I get any car work I just move the supra out of the way and work out of my garage.
Busy night at the shop,
lppro
Apr 21, 2007
895
the wiring harness pulled through the intake side of the firewall,
cleaned up the trunk a little more,
injector wiring,
i was tired of seeing my interior all messed up and dirty so i cleaned it up a little to,
anyways, slow but steady progress...
lppro
Apr 21, 2007
895
ok, did a little cutting and welding today!
I decided I wanted to make the rear tire well flat so the battery box would sit level and nice.
the welding didn't come out perfect but it wasn't bad considering u was using my little mig with flux cored wire.
