lowering
supraken
47
pensacola, FL
I want to lower my mark III 1" to 1 1/2" does anyone have a setup like that they would recommend, and will the TEMS (Toyota Electronically Modulated Suspension) still work/ is there a way to make it work???
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
LOLOL what's TEMS again? I thought it was like Toyota engine managment system or something.
Ok, seriously tho. This is a good place for parts.
http://store.driftmotion.com/Static/Category87.php
Their are two types of lowering springs on there. And yes TEMS will still work.
Clied
Wangan Supra
Jun 8, 2006
367
NorCal
Heres my car with B&G lowering springs(mind the sawblades). You can still use TEMS with lowering springs, It's all in the shocks you use. Although I wouldn't recommend using your stock shocks with lowering springs as they might be blown and there not made to be used on a lowered car. Look to Tokico for TEMS compatible shocks if you want to keep TEMS so bad. I'd ditch em though and recomend Bilstein or Koni shocks.
Bilstein is what I run now with stock springs set to the lowest ride height setting. It handles great!
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
yes theres about 100 diffrent set up's out there for somthing your looking for.You should search next time.Look around a bit there is a whole thread on almost every set up out there.
also if you want to keep the tems the only shocks I could think of is tokico illuminas(thats what I have).But tems isn't all that.It just depends on what you want
