Lower Ball joints bad; q's
Supra5MGTE
421
Tampa, FL
Ok, when doing the brakes i noticed i could move the knuckle up and down... lower ball joints on both sides are shot. Q is, should I do the upper and lower? how hard is it to do this job? any advice before I go buy the parts? where Should I buy the ball joints at? I"m thinking napa or dealership.
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
U mine as well do both I would!!!! I'm just gessing but the dealership mite cost a little more.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
ya there is a lot more load on the lowers, so they wear out first, uppers need to be pressed in and out i think, but im not positive..
Uppers are non replacable as far as I know you have to go genuine and buy the complete A Arm as they're one piece.
Joel is correct though there are minimal loads on the uppers so they don't really wear out.
Lowers are an easy fix :)
(Only thing on our cars that is so they must have had a visiting designer from another company that day)
Ckanderson
2,644
The beach
lol yea never had a problem with any balljoints or suspention components of our cars... thank god... balljoints arnt always the most fun thing...
JustAnotherVictim
They're easy as long as the bolts don't strip then you're in for some trouble, I've done upper and lower on mine and it wasn't too hard. Then we did my friend's car and the bolts holding on the ball joints stripped while we were pulling it off so we had to replace the whole arm. Which still wasn't all that bad
Supra5MGTE
421
Tampa, FL
Justanothervictim- Did you have to buy the whole upper A arm when you did the uppers? or just buy the upper ball joint from to yota?
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
the lower ball joint you can buy from your local parts store,the upper is a complete unit.costing AUD$380+ea.You can buy JIC upper arms with camber adjustment for less i believe.
