low oil pressure
jdub
Feb 10, 2006
10,730
Valley of the Sun
I would...you need to get that plug out too. Just for future reference, put nickle anti-seize on plug threads.
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
Alrighty round 2 tomorrow. Nickle anti-seize? Well I have PB blaster, and wd40 has been soaking for 2 days. I am not sure if the pb blaster is safe, but if it is I will give it a go.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Use the PB Blaster...better than WD-40 IMO.
Too late to use the anti-seize...you have to put it on the plug threads when you install them ;)
northwestsupra
1,166
Washington, Marysville
so yea im just going to pull the brain fart card :p it was pretty late also so i was in a hurry to pass out i think :) just a personal choice and recommendation, i would get new plugs after this lol and anti-seize them. and x2 on the PB blaster, that is what i was thinking of before but i just couldnt put my finger on what it was called again lol
Bri7man
Jul 17, 2009
580
Torrance, CA
YESS!! Breaker bar let up. I thought eff it I'll just give it all I got and it came out clean!!!
I killed my battery earlier with accessory on so I got a overnight charger on it and tomorrow I will do another compression test. It will be a wet/wet test I believe since there is already oil in there from my previous wet tests.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
good info about the mic and caliper.. I learned some new stuff about the micing stuff. ;)
I see you have the same hassle as me with the knocking. :/
northwestsupra
1,166
yea thats how i learned at least in my engines rebuilding and performance class. used the inside "telescoping" to get the diameter of the cylinders and just used the outside ones to measure the inside mic for accuracy reasons. we also had a bore gauge, but only used it for a little bit not much practice time on that. but you can do just about anything with the 2 combines, measure the cam cap to head, or main caps to block, basically anything with a bore lol. then just use the outside mics to measure what went inside the bore and compare the differences and go to what your specs should be :)
there is a tool for just about anything just need to make sure you use the right ones :) way worth it in the end
Bri7man
Jul 17, 2009
580
Torrance, CA
so my cylinders are wet from yesterday's test and I'm wondering if I should hook everything back up and let it burn off before I start another compr test or what?
Bri7man
Jul 17, 2009
580
Torrance, CA
I ran my car for about 10 mins to burn off the oil used in the previous test, but I don't think it was all burned off.
Reason being my compression test I just did gave me numbers from what a wet test would be in my last results.
I held WOP this time and did everything right with car battery being jumped through the whole test at 13.60v
Results:
1)179,177,179
2)175,180,181
3)177,179,181
4)179,179,179
5)173,175,178
6)179,181,181
Well there's your difference in numbers!
Go for a run around the block then repeat breathing through a straw and with bricks tied to one leg and see which fills your lungs better ;)
