low compression on cylinder 6
BryanDyer
654
Georgia
ok guys so I did a compression test last night
all cylinders were between 180-190
I did 8 turnovers on each cylinder, Wot, cps unplugged
but 6 I only had 119 psi
so I went ahead and did a wet compression on that cylinder, added a cap full of oil turne it over to get the oil spread then tested
it only went up to 130 psi so this is only an 11 psi increase
is this significant enough to be the piston rings? or does it sound like a valve? I was going to do a leak down test but if like to know if it's the head or block first
IndigoMKII
2,181
Madison, Virginia
On the airplanes I've done where we used a compressor fitting to pressurize the cylinders, if it was the rings you can hear it in the dip stick tube whereas if it was the valves you could hear it in the exhaust/intake. If you do pressurize the cylinder make sure you put a breaker bar on the crank and slowly increase the PSI into the cylinder.
Also, did you test the compression on a warm engine?
BryanDyer
654
Georgia
I've never actually done a leak down as I have never had to
so could you explain step by step exactly what to do?
I know I need a fitting and need to pressurize the cylinder and listen in the exhaust/intake and I guess dipstick
how much air do I put in though? just need an explanation
What kind of hg?
No 6 is 1 of the most common cylinders for a bhg.
Can also do a leak down test to see whether its rings/hg/ or valves.
IndigoMKII
2,181
Madison, Virginia
I normally put in anywhere from 80-100 PSI. Like I said earlier, make sure to feed it on slowly so you don't turn the engine over.
BryanDyer
654
Georgia
hvyman;1947133 said:
What kind of hg?
cometic mhg with arps
only 3000 miles on the hg
