low clutch fluid question
shadow8450
kingston ny
what would cause this because my clutch is slipping and i refill every other week. also what would cause the brake warning light to pop on do our cars have a proportioning valve?
shaeff
Kurt is FTMFW x2!!!!
11
Around
if you have to keep adding fluid, chances are that you have a leak somewhere, or lots of air in the line, or a combination of both. check your brake fluid.
does your car have ABS?
-shaeff
edi
198
www.pxracing.com
i have to refill my clutch fluid reservoir once in a while but that's because its leaking from the clutch master cylinder. that might also be the cause for you.
isn't the clutch hydraulics and the brake hydraulics two separate systems?.. that's why there's two separate reservoirs.
shaeff
11
Around
yes, they're two completely separate systems.
-shaeff
shadow8450
kingston ny
-shaeff
its without abs
gsx750r93
WARRIOR MANGO
Dec 1, 2006
103
seatac
Hey sense your on the topic of clutches my car has been sitting for about two weeks. Two weeks ago it round fine and everything. Well just got my new ic pipes and maft pro installed. I went to start it for the first time and when i pushed on the clutch it went all the way to the floor and i had to reach down to pull it back up. Any suggestions.
p5150
ASE and FAA A&P Certified
Central Idaho
Time for a new master cylinder
gsx750r93
WARRIOR MANGO
Dec 1, 2006
103
seatac
New master cylinder?????? It was working fine the last time i drove it then all the sudden when i went to drive it the clutch goes to the floor
