LOUISVILLE SUPRA MEET
mkiiSupraMan18
Needs a new username...
United States
Ha!
The trans I sold you was teh suxorz Jeff!
2 weeks... I better tell my new job I need off. Oh, and I work at Advance Auto now, gonna take 'em to the cleaners w/ my discount *No, not 5 finger ones*
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
:rofl: :rofl: :rofl: :rofl:
I can just see Matty Poo now in his cute little half black, half white shirt walking around Advanced....:rolleyes:
Glad I could help brother. I was hoping and praying that it worked, but I knew I had another one somewhere if that one didn't work. I hope you get the tranny problems solved. WoooHooo, Suprahero saves another supraowner in distress. I think you make number four that I've saved.....................lol
After rethinking what I've sent out, you make number six. You're the only Korean that I've saved though...................;)
Boost Lee
2,750
Indianapolis, IN
^Sweetness. lol
Well, I was on the cygnus1 site and connect Tt & E1 or whatever, and it wouldn't flash. I disconnected the two, pulled the DOME fuse, repeat, still didn't flash...and no, the OD light was NOT on...I can't even turn it on because it's not connected...So...With the speedometer not working and a flashing thingie mabobber trying to tell me that something is up with the tranny...I'm glad my car is running again, but this just isn't making any sense...:icon_conf
Frusteration starting in 3......2.......1.....:(
:nono:
Steve_N
Louisville KY
Boost Lee said:
^Sweetness. lol
:nono:
Dome fuse needs to be in. Only pull that out then replace to cancell the codes. The O/D button must be pushed in. It needs to be in the on position so the O/D lite on the dash will show. Once you jumper Tt - E1 the O/D light will flash the codes. I didn't read befor that your speed O wasn't working. You more then likely will get a code 61 or if you had the Inst. cluster out & replaced a code 42. Anyway start shopping for a new speed cables. W/O proper working cables in an auto you will have several other problems.
mkiiSupraMan18
United States
While we're on the topic of speedos....
Mine is reading about 20mph(ish) fast...
NA speedo, Turbo trans, NA Diff... ?
Do I have to swap out the diff AND the speedo to make it read true? Or is something else F'd in the A?
And 10 psi on stock everything (except BOV) wtf? I've seen hit hit 12, and once 15 (but I hit FCO when I hit anything over 10... ?)
Steve_N
Louisville KY
Does ithe speedO show your going 20mph while stoped with the car running? What does it read when the car is off? Auto or 5spd? I don't think its the Diff,trans,cluster combo thats causing the problem. May be a bad speedo cluster.
mkiiSupraMan18
United States
sorry...
0 when I'm sitting and the car is off...
Automatic.
Ghey, I figured I'd have to pull that friggin cluster out... AGAIN. I KNEW I should have swapped out speedos while i did the tach swap.
PAIN IN THE ASS
Fuzz420
Are U Here 2 take My Baby
Fuzz420 said:
Welp the supra is down for now. :(. Gotta order a gasket for the trannny, then most likely a new master cylinder.If im lucky there wont be any harm done to my clutch or tranny.So right now im drving my dads big bad 90 lexus ls400 :). My goal is to get these recent problems fixed and then tear it the rest of the way down and do a mhg.Its going to be a photo finish by the time the 14th gets around.
Can any of you locals get me a good price on a cometic hq and arp studs?Just pm me if you think you can get me a good price.Thanx
Pffffffffffffff, boy was i wrong. The driveshaft may or not be toast.The d/s is at a specialist so i should be finding out monday on what can be done.
dbsupra90
toonar
indiucky
st2b said:
So is there a set date, time and place yet for the meet? Sorry I haven't been on here in a while..
yes! oct 14th. time will depend on how many are confirmed to dyno. most likely around 11am or so. will decide that the week of the meet for the exact start time. place is in louisville, off outer loop. afterwards is food and maybe drags down in BG.
Boost Lee
2,750
Indianapolis, IN
Yaaaay, First day officially having a "sort of" healthy car in a while and I break it racing and spanking a 1500lb swapped and built motor CRX spraying like 75 shot....Anyways, Question for you fellers that are familiar with different hoses that are sort of deep down in your motor...
The hose itself (like a 3/8" hose), blew on me AFTER I had shut the car down...at first, I was like, "OH GOD, NOT BHG:(", but I found quickly that a hose had cracked...
Now, to try to explain it...
One end of the hose goes up INTO the Intake Manifold from the bottom side...and the other end of the hose goes to some little nipple-type plug that sits right below the manifold...It is some sort of coolant line...but I'm not sure exactly WHAT it's going to, where it's going, and if it's even necessary...
I was stuck out in Greenwood and had no choice, so I just cut the hose in half where it had cracked, and stuck 2 bolts in each end to keep from losing anymore coolant...I'm "assuming" it is some sort of way of keeping the manifold cool...but I didn't know if it served some other purpose...Well, anyone have any idea what it is? :icon_conf
dbsupra90
toonar
indiucky
jeffy-
that is the coolant line that loops thru the throttle body and isc. doesnt keep it cool, the opposite. it keeps it warm so it wont freeze up driving in arctic conditions. i took all that off my car and just made a single loop. we did the same thing on chris's.
mkiiSupraMan18
United States
^ Duh Jeffy.
Sheesh, after the past 2 years or so you haven't picked up ANY of me or Jon's JDM tyteness? pssshhh... and I thought Koreans learned fast.
