Loose Shifter
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Okay so my friends 1988 Supra shifter is all loose. Its loose in neutral and also when its in gear. Could this be caused by the bushings on his shifter? If so any one have the part numbers and website I can order them from? Thanks:biglaugh:
mirage83
457
Georgia
Auto or manual tranny? I just got a set of bushings for my auto '88 shifter from my local Toyota dealer, as my shifter was pretty loose and sloppy though it still worked. Part# 90385-11003, cost a couple of dollars is all.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
buckshotglass;1111193 said:
How many pedals do you have?
I got Four Pedals................:biglaugh:
Its a Manual BTW. Which is better Marlin Crawler or the Green truck bushings?
Also are those all the bushings im going t need to correct this problem?
steven89
892
Houston, TX
yeah, you just need those 2 bushings. I had this crazy play in the shifter too before I got these bushings.
I have the marlin crawler bushings as well. As far as I know, they're just stronger [polyurethane?] stock ones.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
i used the toyota 'green truck' bushing and it felt as stiff as my other car which had the marlin crawler... just make sure you grease them up really good and that way you wont have a hard time shifting like most people complain about...
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
my shifter jiggles in any gear...and 5th feels kinda..."out there" if you know what i mean.
I'm guessing I should get these too then?
Thanks +1 on those parts numbers.
Could I fairly easily remove my shifter and replace these and fill my tranny with fresh fluid while I've got the shifter out? I think my tranny could use both...
I need to search on the tranny drain/fill tips with this method. I'm guessing i'd drain, cap the drain, open the filler plug, then pour from the top until some runs out the filler plug, right?
-----EDIT
holy poo is shipping a fixed 20 dollars? that's more than the damn parts! i must have screwed up somewhere.... did I?
