Looking for lower ic pipe kit...cooleeze out of business correct?
InFrnt0fU
Lurking Supra Socialite
I'm in dire need of a replacement for the lower ic hoses. I'd prefer a cooleeze type kit but I'd settle for new rubber hoses. Anybody know where I can get either of these.
My car is running rougher than a sandpaper condom fyi.
it's still cheaper than replacing the parts from the dealer at nearly $100 for each section (lower hose is two sections)
spinningheadboy
Ich bin gegan alles
idaho
I have the speed source lower pipe. It fits perfect and was cheaper than the stock replacement. I've had it on for two years now with zero issues.
cwd
themadhatter
760
Vegas
cwd
I have had my speedsource lower pipe for a year now and i have had zero issues with it
jtran8
199
wichita kansas
If you only replace lower intercooler hard pipe , you still have stock upper intercooler pipes and hoses which is just a waste . If i was you i would buy ebay 2.25" intercooler hard pipe kit for $125. which include straights + 45 bends + 90 bends pipes + 45,90,straight couplers and t-bolt clamps . that's all you need to complete replace your intercooler hard pipes ; 2.25" intercooler pipes are good for stock and 57trim ct26 also work great with stock intercooler or after market . CT26 compressor outlet dia. is 2.25" and 3000 pipe also 2.25" . with complete intercooler hard pipe , you'll notice big different in turbo response .
mkiii222
Troy, MI
Another extremely satisfied SpeedSource customer. If I had to do it again, I'd still buy the SS one.
Sure it doesn't come with the upper, but the upper pipes aren't normally in bad shape.
BTW: wasn't SS working on the upper kit???
ethan12510
12
Queensbury
Is Cooleeze out of Business? I orderd A full hardpipe kit on 7/16/08; he said it was in stock (I have not seen the kit yet though). I also have the SpeedSource pipe and it works great.
InFrnt0fU
I'll hold out and wait for speedsource's kit. I actually put some t-bolt clamps on the 3000/tb and got a lot of improvement in running condition. I think I'm just going to replace everything with t-bolt clamps and silicone couplers where possible.
ethan12510
12
Queensbury
Just talked to Greg at Cooleeze, he said that Cooleeze is still in Buissness. He said he has another job now, which is the cause for the slow responses.
