Liquid to air intercooler. ebay brand? i got a few questions
By all means if you have a constructive arguement put it forward but if you've read and comprehended my posts I don't think you do other than weight and complexity which I already mentioned.
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
im currently about to finish my A2W setup so hopefully it goes well
cost me a good 400 just on the intercooler and radiator! oh well..
maybe it will do be good in the long run
frontierguy25
968
TX
I live here in TX and drive my car daily in TX heat and TX traffic and I seem to do Just fine with my A2A IC. I do have a koyo rad and good clutch fan with it as well. It doesn't get hot even driving for hours. But good luck with your setup.
sportinct26
105
cali
really? doesnt the car feel sluggish a bit?
i had a 57 trim turbo(not a ct26) not to long ago and set boost at 18psi. it feels like a different car when its normal temp out than when its hot out.
when its hot out its just not pulling as hard.
on a stockish boost maybe it wont make much of a difference?
sportinct26
105
cali
what do you mean by complexity? it seems simple to me. maybe im missing something. i mean its the relative the same.
piping from turbo >IC>piping to throttle body. BOV in bitween.
^^ the same.
except now theres a cooler. so its
heat exchanger > pump>ic>heat exchanger
^^right?
and wiring for a the fan and pump and controlled via hobbs switch?
i mean its a bit more work but i think the gain of not heat soaking is well worth the "extra" bit of work.
next question is how much weight difference?
i plan on installing this inside the engine bay and make some sort of cage to isolate it. i wanted it inside for shorter plumbing.
I read that shorter plumbing reduce lag? how true is that statement? would it be notisable?
BTW this is not for a supra set up. this will go on a 260z with a 7m.
W2A will keep the charge temps at close to ambient in traffic the A2A DOE heatsoak like a bitch I have IC In/Out temp sensors and have logged this in the MoTeC, while the temp rise doesn't have a big effect get on/off boost a few times and management HAS to pull power to compensate (if your ecu is advanced enough that is)
sportinct26;1196222 said:
what do you mean by complexity? it seems simple to me. I read that shorter plumbing reduce lag? how true is that statement? would it be notisable?
A2A NO electricity NO Water NO Moving parts so W2A is far more complex.
Perceived Lag is usually other factors, I went from 2.5" pipes to 3" and noticed a drop in lag on a 3540r, as for shorter pipes you need to look at the gas speed through the system it's usually quite high and an extra foor of pipe isn't going to make a difference BUT having the IC in the engine bay IS making it less efficient as it's starting from a higher temp state.
