Lipp Fuel Rail Problem
92nsx
2,957
Clearwater, MN
Re-install OEM fuel rail and call it done ;)
And Duane look what you started with putting you name here^^^. :biglaugh:
scubajtw
SupraSport
Mar 6, 2008
159
Minnesota
sprigmo1;1217995 said:
I'm having a problem getting my780cc PTE injectors to seal in my LIPP rail! I've tried all I can think of and nothing seems to work completely! Any ideas! New o-rings already installed!!
as you are tightening the rail down try to turn the injectors as you tighten is slowly. I have never had a problem with mine doing it that way. i also us a little grease on the o-rings to let them slide better. give it a try!
Dec 3, 2003
6,653
Canada
I run an OEM rail which I drilled and tapped for a -8 feed and has a -6 return. Car makes over 800 RWHP through the GM auto. ;) In essence, the OEM rail will do fine. Not sure the limits of it yet but I'm sure I will find out eventually.
lol
Duane
northwestsupra
1,166
Washington, Marysville
ok i know this thread is hella old and past 138 days, but the question never got answered, i have an answer because i ran into the same problem,there are 2 parts on the neck of the PTE's, there is the lip which is usually where the o-rings are placed when you get them, then there is a black section just below it, put some vasiline on the o rings so you dont damage them, and pull the o-rings to the lower section "black part" now the o-rings will sit on the chamfered portion of the fuel rail, and the injector will sit higher up in the rail. see i bought one of these because i was running a full -10 AN system, with dual feed -8 and a -6 return, i dont have the tools to do the modifications to the stock rail, as for looks, it looks sick :) i dont have doubts that the stock rail can flow great, but sometimes you just have to go overkill
sprigmo1
78
Waldorf, Maryland, United States
I ended up getting a new rail from SupraSport (great guyz) and using a thick washer on each of the three mounting points to keep the inj from going too far into the rail. Dual Walbros pumping strong and no leaks. 2 -6 feeds out of the tank into a -8 single feed to the rail with a -6 return through a Aeromotive AFPR. Now once I figure out why my damn oil pan has a pin hole leak at the seal...............!
Thanks for the reply!
scubajtw
SupraSport
Mar 6, 2008
159
Minnesota
Just a little FYI on the rail issue the rail itself is just fine. I am actually running it in my car right now no leaks at all. It is really easy to hook up a -8 line to the supply and a -6 for return. All you have to do is let Jack at suprasport let you know what you want and he will make it happen.
figgie
Twin Cities, Minnesot-ah
Poodles;1218417 said:
800HP isn't outflowing the stock rail...and looks are subjective.
Pressure delta! ;)
At 800hp, you are talking a significant amount of fuel flow, the ID of the stock will not make the fuel reach critical velocity but will contribute to the fuel pump seeing higher pressure than a PROPERLY sized fuel rail with the correct ID for minimal pressure losses at the volume that is being moved (same with the fuel lines etc).
True, but it's just a point that for most people the stock fuel rail is more than enough and money could be best spent elsewhere.
scubajtw
SupraSport
Mar 6, 2008
159
Minnesota
figgie;1355116 said:
Pressure delta! ;)
I know what you mean figgie. It is borderline overkill on my car. But it was way easier then trying to make a factory one work with -8 supply fed by dual Walbros. Soon to be running 1000cc on e85. (once the motor is broken in) I am glad you put in your 2 cents worth of great information.
