limited slip???
mastergrader007
master jimmy-rigger!
Apr 18, 2009
65
Ontario, Canada
hello, i have an 88 supra turbo 5speed and i was wondering how i tell if it is limited slip?? i want to change the rear end fluid but dont know what to use??? could you point me in the right direction?? thank you
Doward
4,245
Alachua, FL
Come to a stop. Rev in neutral to about 4k rpm, and drop the clutch. Hold the accelerator to the floor for a moment, and let off.. See if you left one or two stripes.
It's like a pregnancy test, really.
VERY easy way to tell: Jack up the rear, put the car in gear (enigne off) and see if you turn either of the rear wheels with the parking brake off. If you can, the opposite wheel will turn the other way, and you do not have LSD. If the axles seem locked to each other (if you can't spin either rear wheel) you do have LSD.
BernieK
dumbo
1,913
Albera, Too Far North
:biglaugh::biglaugh:
PERFECT :rofl:
Zumtizzle;1310806 said:
Go to ford and ask for friction modifier and use a couple ounces.
Also Ask them for 75W-90.
Shouldn't need more than an oz ;)
I'd start with 1/2 oz and go from there.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,585
Great Lakes State
Here you go.
paradox616
472
Melbourne, Australia
i like your theory, except 1st is more fun, see after you run out of steam you can go to 2nd, its like tetris.. my best is level 3...
Hmong_1G
Name the Place and time.
Dec 31, 2008
280
California
Bringing an old thread back. I added the specific amount of diff fluid. I went with MOTUL 75w-90 oil ( synthetic blend). I've heard that the MA70 turbo diff with lsd doesn't like anything synthetic. True? I was thinking that I might switch out for some regular Valvoline 75w-90 weight if this is the case.
Unless you mix two of the same brand...start with one quart of Redline 75W-90NS and top off with 75W-90. A lot of sucess with this one.
I use straight RL 75W-90 on a rebuilt TRD LSD...no issues at all.
grimreaper
2,180
Dallas
crap i added 2 oz of the lsd additive. start with 1/2 oz huh? might have to drain and refill.
No chatter, or slipping for that matter. But i dont usually lay down rubber either...
toyzforme
I need deeper pockets
Jan 1, 2008
103
Summerville, SC
I just bought all new clutches for my LSD from Champion and he said to use the Royal Purple 75W-90, isn't that synthetic. I and rebuilding it so as to get out of the corners better during autocross meets. I hope it works
