Lightweight Driveshafts "worth it"?
RIPDOTCOM
157
Tallahassee, FL
Is there a noticable benefit in going with a lightweight driveshaft? Are there composite/graphite driveshafts available for the MKIII NA 5-Speed? Anyone have a source for a low cost aluminum direct replacement?
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
Wow are you in some serious luck. Aluminum driveshaft available from HorsePowerFreaks for only $419 I believe. They ordered it on accident (They meant to order one for turbo). I suggest you get it now before someone else does, once it's gone the $460 original price will be back in effect.
JD7Monster
Orlando, FL
I have the aluminum 1peice from Suprasport.com, they order from the driveshaft shop.. i'm sure HPfreaks order through the same plac.e
But yes it did make a noticable difference, mostly in the way the clutch engages/starting out..
boost fiend
852
Rockford, Il
of corse a light weight driveshaft makes a diffrence. would you rather moove a 50 pound object or a 15 pound object? not only that its less weight to get mooving. if ya got the money to get one GET IT NOWWWWWWW!!!!!!!!!!!!!!!
rakkasan
Currahee!!
Fort Campbell, KY
JD7Monster said:
Suprasport told me the stock 2peice weighs 33-38lbs, the aluminum 1peice weighs 13lbs, BIG difference
I weighed mine when I had my tranny being rebuilt. 45 lbs (w/ center support). This was done the non scientific way, my weight holding it - my weight only. :biglaugh:
Anywho, It's a big difference.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i installed mine two weeks ago.i love it.i can notice it mostly down low in the rpm range.it was a driveshaft shop aluminum one
americanjebus
Mr. Evergreen
wa.
supradan the answer is yes,
didnt we discuss the benefits and downsides about this. somethign about inertia at higher speeds?
shaeff
Kurt is FTMFW x2!!!!
11
Around
supradan22 said:
So theres a diffrence between the turbo and the n/a DS
yes, they're different lengths. i strongly recommend that anyone considering an AL driveshaft, consider a lightweight flywheel FIRST. its a MUCH more noticable difference, and it's felt throughout the rpm range. i love my fidanza.
a lightweight DS makes way LESS of a difference than a lightweight flywheel. the flywheel is a far better investment, for about the same price.
-shaeff
shaeff
11
Around
ma71supraturbo said:
Downside to the flywheel is that its not a simple install and should be paired with a new clutch...
true, very true. good point, my friend :)
-shaeff
supraaddict87
59
Morgantown WV
www.geocities.com
I have purchased a lightweight flywheel I got for a good price from a local guy, but have just gone through a rebuild and installed an RPS 6-puck sprung clutch. I didnt really want to tear everything apart right now to install it and have planned a more extensive rebuild in the near future. My question is, will I have any problems using this NEW flywheel with my clutch if it has 3000 miles on it and already broken in on a factory resurfaced flywheel?
sorry for the thread jack,
mike
mkIIIman089
Ohio
You would have problems with slipping; since the clutch disk is already seated for the factory disk I don't know if it would accept the new perfectly flat flywheel surface.
