Lexus AFM
Obsessionw/Boost
198
Albany, NY
I want to upgrade to a Lexus AFM and RC550's but right now I only have money to spend on the Lex. Would I gain anything upgrading my AFM and running my stock 440CC injectors? Would it cause me to run lean?
I'm running a stock CT26@10psi. I don't want to get a Lex now, and it isn't beneficial at all. Even if it will help me a little bit, I'll get it. What do you guys think?
-Ryan
marlonvip
Supra -only way to fly
Sep 2, 2006
189
Denmark
Dont use the lex without having the 440 cc injectors flowtestet first................big chance of running lean with the lex and NO rc 550:-(
huntin5L
Niles, IL
Even if he did put on just the afm, which i know is a no no, wouldn't the fuel cut stop the motor from becoming to lean to cause harm to his motor?
Obsessionw/Boost
198
Albany, NY
Okay so if I were to get the Lex without the 550's, it would lean me out. That's the last thing I want to do. I'd rather run rich than run lean. I've honestly never seen a Supra that doesn't run a little rich anyways. Thanks for the input fellas!
-Ryan
huntin5L
Niles, IL
Yes that is what star is saying. I wasn't exactly sure about how fuel cut would play into it with just doing the afm upgrade. What he is saying is your ecu thinks it will be getting less air than really is, which will cause you very lean mixtures. A big no no. Horsepowerfreaks has the injectors for very decent prices, just wait and get them to do this right.
-Ryan
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
People run with the stock injectors and Lex AFM, but they're dumb if they don't have the devices to see how the motor is reacting to the setup and some way to tuning it if it goes too lean. I don't recommend it, but I'm sure there'll be a few comming on here shortly saying "I'm running teh lex AFM with stock injectors, no problems here."
8,900
By right, you should use the 550's with that airflow meter. But the stock settings are very rich to begin with. Less air observed also equals more timing.
I would not run the Lex meter with out the bigger injectors.
mkIIIman089
Ohio
I'll oblige. :)
Starting with a clean slate the stock ECU will be able to correct out 90% of what the Lex AFM does with 02 sensor feedback, in an otherwise stock setup.
While its not all I'm running, I do use the stockers with a Lex AFM.
Also, you're in for a serious shock if you think I'm dumb.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
How's your motor fairing with your setup? There's been others on here have engine failures with this combo before. Do you think it's becuase they don't reset the ecu and/or have no way to increase fuel pressure or upgrade the fuel pump, etc?
What exactly do you have on the motor as is right now? Still a secret? That's what your profile says ;)
mkIIIman089
Ohio
Fine so far, it has been ~8k miles with it like this, no problems.
I think that when most people do just pop it in there and call it a day, then go out and see if fuel cut is gone; they frag their engines.
When I was 1st experimenting with it by itself, I reset the ECU, then drove it for a little while very lightly so that Vf would stabilize. It still ran 14.7:1 under cruise, only leaned out at idle; Vf was locked on full add to keep it like this mind you. So I did a 3rd gear WOT pull and A/Fs were still in the 10s from 5000-up. (Which was hardly a change at all from where they were with the stocker)
If you're really interested I can probably find the Zt-2 log file still.
I'm now using the ZT-2 narrowband adjustable switching point and an SAFC. Everything else in the fuel system is stock.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I am assuming you are running your engine in tip top shape too. Think of what condition the sensors are in, in a lot of these +20 year old supras. A lot of people don't understand that a faulty sensor coupled with the lex afm could be disaster. Such as an o2 sensor on it's way out.
I find it amazing that the A/F's are that rich, plenty of room for improvement ;).
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Hey man post it :)
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I agree. This would be great information to sticky, with a big note that this is what it's supposed to do with a careful eye on the A/F's, a reset ECU, and properly running electronics throughout. ;)
mkIIIman089
Ohio
Hmm, looks like the original log file I had was deleted. I only have the tuned log files now... I think if people saw them they would shit themselves to think a car can run like that, LOL.
As far as my engine, when I did that all of the sensors were originals, no codes, no perceptible issues with it what-so-ever. Now the only difference is a new CPS, plus I'm obviously using the ZT-2 to simulate the narrowband signal. I will also add that was before I had the SAFC as well, so there was zero input from any kind of scaling device.
Yea, A/F's were still that rich. That was the point in time when I pretty much stopped believing nearly all of these "experts" on the internet. ;)
My own sticky, eh? :D
