Just being curious, how do you know it's rich unless you have a wideband?
The point to lex afm and 550cc injectors is that they don't need tuning. Both are 25% bigger than their counter parts.
Keep your fuel pressure set to stock, 33-40 psi with no vacuum. As for your afm screw location, hook up a multimeter to your vf/e1 ports in the diag box under the hood, your goal is to get VF to read 2.5 volts. You will have to play with both, the afm set screw and the fuel pressure.
Since you're able to adjust the fuel pressure, I'm going to assume you've also done a walbro 255 fuel pump swap and bypassed the j-tube under the intake manifold?
What other mods do you have done to the car?
