ok i understand that if you use a lex afm on the stock 440s it will cause your car to run lean correct if i rember. i have the warlbro in tank and a afpr. will i still run lean with these mods. i did some mods to the lex afm so i can adjust the open bottom half of the lex afm to make some adjustments. and yes i did this mod with a longer screw to block it off. will this still be bad to do with the mods i have just told you about. i also have other mods like intake and exaust too.
