knock sensor????
eric783
32
Bremerton, WA
what if i ran the supra without a knock sensor? i broke it at the plastic piece with the wire that goes in the metal coupling, can i just super glue it or rtv? a new sensor is worth alot. are all toyota knock sensors interchangeable??? i.e. camry, cressida, ????? please help me????
I don't know for sure, but if you ran it without a knock sensor, it seems to me that it would throw a code 52. You can usually find someone on here that will sell you one, or you can pick one up at your local junkyard maybe. I would just replace it instead of trying to rig it up. Good luck.
shaeff
Kurt is FTMFW x2!!!!
11
Around
Grab one out of one of the many same-era Toyotas found in junk yards.
eric783
32
Bremerton, WA
oh wow!!!!! so i guess i should just cough up the 200 bones and get her done, huh? thanks guys, i can always count on other supra owners for support......me likey!!!!!
mkIII213
87
Dallas, Tx
AJ'S 88NA;1043949 said:
With out one the ECU will retard timing.
What exactly do you mean by retarding the timing? I am getting a code 52 because the little cord was pulled out of the knock sensor plug. The engine is running a little rough, is it partly due to the knock sensor?
jetjock
creepy-ass cracka
9,439
The ECU is aggressive in setting timing. It depends on the knock sensor(s) to do that. If it sees the sensor isn't reporting back it automatically retards the timing to protect the engine, sets a code 52, and lights the MIL.
mkIII213
87
Dallas, Tx
So in getting it reconnected and fixed, it should run alot smoother and the timing wouldn't act like its a little off?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
EDIT:
I suppose I should further qualify this by adding: :icon_bigg
viper92086
932
NJ
they are the same, i've used both in my na-t and they both seem to be the same. i do recommend doing a rewire with all new connectors tho.
AJ'S 88NA
2,419
Florida
supra_89_vang;1102345 said:
I have the same problem with my knock sensor. How do we test for a bad sensor?
I don't think there is a test for the KS.
Anybody else having trouble getting the TSRM on line?
supraman508
496
maryland
I have the same problem,my timing is lacking and i'm burning to rich with the outcome of black smoke and a gas smell in my oil.i found a knock sensor on ebay for under 40 bucks.don't you dare go to the dealership:3d_frown:unless you were born with a golden spoon in your mouth:biglaugh:
supraman508
496
maryland
also since were on this topic if you have a bad ks can that prevent your speedohmeter needle from working?
