Knock sensor problem and how to fix it
Projectmk3
1988 hard top N\A
Jun 20, 2007
Ontario
i had a knock sensor code (52) ever since i had my car a (year next month), i finally broke down and tried to get to the root of the problem, my motor is jdm so i knew the knock sensor was still good (provided the fact that they hardly ever go bad) so i disconnected and cleaned the plug, still threw the code (after i reset the ecu) then i said F*^k it I'm gonna rewire it, i sniped the wire about 21/2 inches away from the plug then jumped it to the car and did the same for the ECU (clear cover with copper wire, second plug to the right i believe) then got about 5 feet of wire, soadered and shrink wrapped both ends, reset the ECU and BAM no mo code 52...it kinda getto cause i didn't bother to take the time and yank out the old wire or even put the new wire into the harness but all and all it took me 15 min. and i just used tape to cover and put it with the harness...put the time in and it will come out nicer but thats for another day
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
go to a junk yard and pick you up one cheap....might as well get you a few....so if one doesn't work then you can try another...
Projectmk3
1988 hard top N\A
Jun 20, 2007
Ontario
jetjock said:
You both had the same symptoms as a result of different causes. What you did was right. In theory what he did could cost him his engine.
how do you figure its gonna cost me my engine???
