Just got an R154 tranny and...
Alex91Mk3
timeshares exchange
Jun 30, 2006
276
Miami, Fl
it came with the pressure plate on it... i seem to have trouble taking it off..slides out but only a bit...what do i need to do mmm?? thanks, did the whole search thing guys..:1zhelp: ...jsut starting to familiarize myself with the whole clutch system....:eek:ffwall: ...alex
Alex91Mk3
timeshares exchange
Jun 30, 2006
276
Miami, Fl
SLO-MK3 said:
Try removing the release fork.
its the one on the right.. is the release fork behind the pp?
SLO-MK3
Not on the 1jz bandwagon
Nov 4, 2006
246
Plumas Lake, CA
Alex91Mk3 said:
the one on the right? is te release fork behind the pp?
^^ Don't know what all that is, but to remove the fork you need to first remove the slave cylinder, then remove the side inspection plate to access the fork. Grab a hold of that SOB and give it a good tug. Should snap right out.
*EDIT* AAARRRGG you fixed it on me.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Sometimes it's hard to pull on. So, I had to remove the inspection plate from the other side and get a long extension and tap it out.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
its funny when you have too many transmissions =/ ive had 4 this past year and still have 3 in my garage
there should be snap rings remove those first and make sure nothing is bolted on in the inspection cover side
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
There are metal inspection plates on both sides of the bell housing.They are angled a little more towards the bottom.
