i have been slowly building my 88 turbo and it is running really bad i have
t4 mani with t3/t4 86ar turbo
50mm wastgate
jdm bov/recirc
rebuilt race spec'd head, 3 angle valve job, na cams
high flow fuel pump
12 gallon alum fuel cell all snap lock race fittings and lines
hks vpc with 550 chip
huge fmic
2.5 inch intercooler piping
removed egr system
removed evap canister
removed cruise control
removed boost pressure sensor....have aftermarket boost gauge
3" dp and 3" full exhaust no cats ... no res... and a turbo muffler
edit** sorry.. it also has arp studs trq'd to 85 and 1.4mm titan metal hg
it will start and it will run rough, after a few it will even out but when you give it alittle gas it chokes out and almost dies.. sometimes does
it also runs and sounds like it is missing when you give it gas and cant drive it... it bucks and chokes
i have tried to adjust timing and it is about 11 dbtc and throws no codes.
i was thinking maybe the crank is 180degrees out but dont think that is possible?? could it also be the iac or something?? i have tried everything and getting to the point where i will just sell it but i have spent 8g's on just the body work and paint... not to mention the engine and interior
does anybody have any suggestions or ideas.. if you are local to the fort knox area and can fix it let me know... got cash... thanks
50mm wastgate
jdm bov/recirc
high flow fuel pump
huge fmic
removed egr system
