Just a couple dip stick questions..
Turbo Habanero
4,229
Tucson,AZ
So as you can see in the photo's my dip stick is not mounted to my Turbo anymore when i sent my turbo out for a rebuild i had misplaced the stud/bolt.
Also by looking at the photo's is the block off plate upside down ? I'm assuming that the hole at the top is suppose to be at the bottom and thats where the dipstick mounts correct?
So my first question is can anyone tell me the size of the bolt/stud i need?
And second question is i take off the block off plate to flip it around should i expect water to come out?
This should be common sense to me but better safe then sorry
Thanks in Advance guys.
Turbo Habanero
4,229
Tucson,AZ
Turbo Habanero
4,229
Tucson,AZ
IJ.;1814392 said:
OK now I'm confused...
Is there an In/Out on the other side of the Turbo from that block off plate??
Its a 60-1 CT-26 stock water lines and Braided Oil lines
The CT-26 is water and oil cooled right?
So yes it's going in so its coming out some where right ?
Turbo Habanero
4,229
Tucson,AZ
IJ.;1814396 said:
Upgrade from the Barbie Camper Turbo?? good idea :D
Trying to save and go stand alone first then go with a GT35R after.
In my head if i do it in this order i can get my motor to last longer.
Still looking for a spare block to build just to have :)
Turbo Habanero
4,229
Tucson,AZ
IJ.;1814404 said:
Is that a stock one?? :aigo:
Yup the first one is the Stock and the one i posted is my 60-1 that Albert made
IBoughtASupra;1814406 said:
Aaron should have his DM kit for the 7M soon or are you planning to go ProEFI.
I've been torn between Pro EFI 128 and AEM V2
I've been waiting for Aaron to release a price for the 89+ Plug in play V2
Now I understand why they don't make power ;)
(I started with a GT30R)
