J-Tube
91Supra313
1,062
Clarksville TN
This may sound like a Noob question, but, how in the world do you bypass the J-Tube? I have heard so much about this and since my fuel tank is out and waiting on a new bracket to come in, I figure I might as well do this mod too. If someone can show me how to do this I would greatly appreciate it. Also, what does this mod do for the fuel system?
Koenigturbo
1,336
Oxnard CA
How I understand it ( I got this info from the reading threads here) this mod is usually done because we upgraded the fuel pump. From reading threads here the J tube has a resriction. You can drill it out. What I did was I completly by passed it. By drilling it, I would be afraid that there would be metal shaving left over from drilling it, how ever, I guess you could blow it out with a compressor.
From what I know the J tube keeps the gas from draining back to the tank, so next time you start your car it won't take for ever to start. I could be wrong on this, but then again I may be totally wrong on the whole reply.
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
That makes alot of sense. My car was hard to start in the morning and I did away with the j-tube also.
Sawbladz
1,727
Oshawa, ON, CA
There is a more important function to the J-tube. If you were out driving and your fuel pressure regulator went out, the J-tube manually restricts flow and keeps enough fuel in the rail to allow the car to limp home. When upgrading to a higher displacement pump, this tube should be drilled or bypassed and you should run it in conjunction with a AFPR. Do not drill the J-tube on the car. It comes off the engine block with 2 bolts.
Koenigturbo
1,336
Oxnard CA
The N/A block has a plate that you can bolt right in it's place if you decide to completely by pass it, or a small block Chevy fuel pump plate will work.
91Supra313
1,062
Clarksville TN
Ok so once the plate is on, where the hell do I reroute the fuel? I am a true retard when it comes to things like this. You all should have seen the hassle I went through with the whole EGR block off stuff.....lol. I just don't want to get anything wrong on this and blow my car up.....not like that would be a first for me.
91Supra313
1,062
Clarksville TN
That will end up waiting until the car gets back to the US in a few years. There is no point in spending that much cash on something that will be sitting in storage for 2+ years, waiting to be shipped.
