j-spec vs. a-spec
shaeff
Kurt is FTMFW x2!!!!
11
Around
they're identical except for the throttle bodies, JDM has no EGR, there's no BVSV on the thermostat housing for the charcoal canister, and the coolant hardline that goes around the block for the heater core is different. thats all i can think of off the top of my head right now.
-shaeff
shaeff
11
Around
gmoney said:
but the power is the same, but the mileage is lower i know that much corect?
yes, the power is the same, and generally, the mileage is lower, between 30-60k miles.
-shaeff
gmoney
supra is as stupid does!
Apr 22, 2005
97
CT
home1.myspace.com
so buying one of those would be a better thing to do rather than rebuilding my engine. due to the fact i wouldnt have to cap off EGR, i would have to pull the engine anyway so i could get rid of my a/c. and my engine is missing alot of misc. parts, and my clutch is slipping as well so its a headache as it is but i need something so my car will run low 13"s high 12's is my goal i figure 350 400 whp with good driving and the right drivetrain could see that.
shaeff
11
Around
eh, it really depends. a JDM motor is like a box of chocolates, you never know what you're gonna get. (read: it could be a dud)
at least if you build your motor, you know what you're working with, so there *should* be no surprises.
-shaeff
Allan_MA70
1,055
Melbourne, Australia
forget about JDM engines now 7m is too old any that are left are well thrashed and have not had a service sence 1992 :p rebuild your known quantity! or buy another dead engine for very little!
shaeff
11
Around
i wouldnt go that far, i got mine over last summer, and its excellent. not a problem with it at all! very clean, too.
-shaeff
Squid699
Manic Mechanic
Chesapeake, VA
one more difference - the vacuum fitting on the top of the intake mani for the brake booster faces a different way for the right hand drive cars.
Go ahead and rebuild your engine, it'll be better off in the long run
figgie
Twin Cities, Minnesot-ah
gmoney said:
woldnt it cost a crap load of money to rebuild a engine?
hmm lets see
zero miles or god knows how many miles
New parts or used parts.
well if you go forged everything . yep. If not. Shouldn't be that much more than a USED jdm engine.
gmoney
Apr 22, 2005
97
CT
home1.myspace.com
i understand what you all are saying, but in japan they dispose of there engines with no more than 75,000 miles thats half of what i have and on my last car i did the j-spec swap and that thing moved and my buddy has a supra with the jdm engine and his car is not normal it hits boost cut with a full 3" exhaust and the k&n drop in, clutch, flywheel and na sport rear end.
Justin
Speakers?
Spokane, Wa
the problem is you hae NO idea what the condition of that engine is in. I would rather spend the 5-700 dollars for the rebuild (doing the labor yourself) than have to pull the engine out in a few thousand miles and rebuild it then because somthing fuct up. Oh. Wait. That's exactly what I'm doing! :)
I'm looking at aprox 500 in parts, a few hundred in machine work, and i'm assembling it myself. MHG, ARP everything. It will be very strong :)
gmoney
Apr 22, 2005
97
CT
home1.myspace.com
well see heres the thing, i had to have a new head put on my car, and the the exhaust manifold had to be bored out to a 1/2 bolt because the shop before f---ed it up bad. so if i rebuild it i need a new head anyway, and my engine is missing alot of parts...
Squid699
Manic Mechanic
Chesapeake, VA
Bottom line: you don't know what you're getting with a JDM motor. Even if it came out of a Supra the day before it hit the docks with 60,000 miles, there's no guarantee that the previous owner didn't run the hell out of it. Rebuild the engine that you have and be happy KNOWING you have a fresh engine. Depending on what you do, it could be in the hundreds or thousands of dollar ranges
Since your engine is missing parts, you might be better finding a domestic donor engine for cheap. I've had luck getting whole parts cars for less than $700 and at least making my money back
thesupraman
Smirker
May 15, 2005
129
Frenchtown, NJ
If you want these goals you're gonna have to put a crap load of money in either engine. Rebuild yours.
Disced
Pie + NYQuil = FTW
Edmonds, Wa
^^ I would like to know what a 'crapload' of money is...
I figure my car will run mid 12's easily after i upgrade my turbo. So far I have spent just under 3200 on my car... That includes the purchasing price of the car.
walbro/afpr/safc/550's/j-tube removal
lex afm/apexi intake
JBL LR elbow/3 inch high flow cat/3 inch mandrel bent exhaust
MBC set @ 17 lbs; falling to 15 @ redline.
stock headgasket from elmhurst toyota w/ arp headstuds.
AMSoil 4 qrts w/ lucas oil stabilizer + Toyota Oil filter.
All on a j-spec engine with a claimed '55000' miles. When taking the head off; valves/pistons looked very clean.
just my .02
Squid699
Manic Mechanic
Chesapeake, VA
just my .02
Yeah, but talk is cheap. It's funny how what you 'expect' isn't what happens when you put it out there.......If you want the car to put out HP reliably, you need to put out the money. And the only way to know for sure is to put it on the dyno or run it. Trust me, my dyno run wasn't what I expected :icon_roll
