WillWorkFoBoost;1785302 said:Nope, doesnt start with starter fluid, or the gas in the cylinders from injectors. has spark now with no misses, at 10 degrees btdc. has compression ranging from 135 to 150 across all cyls. still doesnt start.
When cranking and pumping the throttle Ive noticed after excessive cranking gas vapor/combustion gases come out through the afm housing... (no filter on)..... Im beginning to think itd be possible theres a rag or something in the exhaust manifold causing it to back up??? dunno why else vapor would be going out that way as opposed to out the exhaust. once again Il state also that the static timing is dead on, unless someone custom re-keyed crank or cam pulleys to fuck with me haha. Dunno I guess Im just clutching at straws at this point.
Maybe I missed something or I don't know what but how do you know your electrical timing is at 10 degrees BTDC?
