Isc valve question
917mgte
115
butte mt
so i changed the coolant hoses on the intake side and now coolant is getting though to the exhaust is there coolant running though isc valve that could leak into the intake manifold or trough the throttle body please help!
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Yes coolant runs through the ISCV and TB but I seriously doubt that it could leak into the intake through them. Are you sure you didn't connect a coolant hose to a vacuum port?
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
noel;1554915 said:
so if coolant is supposed to run thru the TB Wats the Piont of PPL capping the TB OFF?? wouldn't THis Make ur TB Run HOtter???
The reason that coolant lines are run through the throttle body and idle speed control valve is for, as Kevin stated, cold weather. The coolant warms the two parts so that the valve and throttle plate don't stick shut due to ice formation.
917mgte
115
butte mt
No i made sure that they are connected to there designated spouts this is really pissing me off i hope its not a head gasket
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Theres no way unless the casting is cracked that coolant could leak there. There is however the gasket between the head and intake manifold that coolant runs threw. Its under the lower plenum.
S.A. supra
2,405
Buda, Texas
Chances are it's gonna be your head gasket. The iscv is not likely to leak. Why did you change your hoses? Did you have a leak?
