Is there a seperate fuse for the fogs?
HIDPLANET
89 1JZGTE
I dont know if I just missed it or if im blind, but is there a seperate fuse for the foglights? One of my fogs was out when the carwas purchased, but when I tok the car from DriftMotion, we tested them and one turned on.
Well now I installed new fogs with a yellow capsule inserted in them but the lights dont turn on. I checked the wires and there is no 12V signal to the foglamp harness at the bulb. So im thinking a fuse is dead somewhere but I cant find it.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
HIDPLANET said:
Ah I see. Its probably hiding beind the kick panel which I have never removed.
Thanks. If you have ever gotten to this fuse, please let me know if you have to remove the entire panel to get to it.
I've taken it out once... actually I should say one of my friends with a MUCH smaller build has taken it out, using a pair of needle nose, WITH the panels in place. Personally, I don't think I could do it.
The panel is pretty easy to take off though. You need to remove the false pedal/foot rest. There's one nut behind it. And loosen the sill. Then pull the panel back (toward the rear of the car. There are a couple spring clips in the long extension which runs up next to the dash, just use a little care.
EDIT: Suprra Girl's probably right, I'm not that flexible.
HIDPLANET
89 1JZGTE
lol, well thanks for the info.
I was able to somehow flex myself into the compartment and remove the lid and get a partial view of the fuses in there. I saw all of them but didnt see the 15A for the fogs. I would have to somehow get deeper in there by the pedals but its a PITA and Istill cant see it. SO maybe i'll hire a midget to pull the fuse lol. Its als odark so with a flashlight, maybe im not seeing something. I'l ltry in the daytime.
CRE
Oct 24, 2005
3,485
Denver, CO
It's not with the other fuses... it's on another junction block, next to the main, and closer to the door. The junction in question has mostly wiring harnesses connected to it, so you may be overlooking it... or you're not able to see around the hatch enough. Let us know if you get it.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
wait only 1 fog light is out? shouldnt both be out if its the fuse? maybe some wires got burnt or cut? if it were the fuse, it would be the fuse box next to the drivers left leg.
CRE
Oct 24, 2005
3,485
Denver, CO
Both are out presently. The fuse is a logical place to start, provided he checked both r and l connectors for voltage. Then if that's fine I'd test the foglight relay.
HIDPLANET
89 1JZGTE
Only one side was working when I drove the car home for the first time a few weeks ago. Now after installing the new fogs, I dont read any voltage on either side. So im looking for the fuse(s). If that doesnt work out, im just going to use the ground signal from the switch and relay to the fogs which is a good idea to begin with for cleaner power.
