is my tranny toast
malloynx
NC
well i have a strange problem. with the rear wheels in the rear; i'm not able to rotate them. almost like there locked in place and the car is in neterual. (sp)
when i push the clutch in, it's the same deal. also i'm having a hard time putting it in first.
i removed the DS and i was able to spin the back tires. i know my diff is fine..
malloynx
NC
hmm i didn't try that. but check this out.. today i was park on a pretty good incline. i push the clutch in and the car did not roll back...
any other things i need to check
malloynx
NC
IJ now that i think about it. i was not able to rotate the DS when i installed my new 1pc..
what would cause a tranny not to spin when it is in neterual
Nope as far as I know all T's had LSD.
If the wheels are turning opposite the LSD is stuffed, try turning the flange and let me know what it does (backwards and forwards)
It's a bit hard to diagnose over the net so sorry for all the questions.
(this sort of thing usually takes a minute or so if you can get hands on)
CPT Furious
Now MAJ FURY!
KDOV
I think that was standard for turbo models, Mike. Can you shift it into other gears with it just sitting? Something happen to the clutch fork?
malloynx
NC
as far as i know the LSD is original.. what do you want me to do???step by step.. what do you want me to check. i don't know why the LSD would have anything to do with my tranny moving while in neterual
K just try turning the Diff Input flange by hand without the DS in place, Wheels off the ground E Brake off.
I've had a badly damaged Diff in the past that would only turn forwards but would lock up when you tried to turn it backwards.
This is just a hunch and if I'm correct it's cheaper than a Trans!
Just doing the process of elmination thing.
malloynx
NC
so both wheels need to move in the same direction??? i thought with an LSD the tires would move opposite
