Iridium Spark Plug ????
suprasport91
GO BRUINS!!!
Sep 27, 2005
336
Seattle, Wa
Same thing as any other spark plug, just be careful, the electrode is a little more fragile than others but you should still be able to
aye mate
Hiatus over.
Maryland
I didn't gap mine. Been in there over a year and no problems with them. I think it depends on what kind of power you are making. My set up is still very stock.
SupraDreamPDR said:
like how high are we talking here? i am planning on running about 10-12 lbs. what should i gap them to then?
Before I re-gapped mine to.027, 16-18 psi. IJ has mentioned that irridiums can glow plug on a hard run. I'm actually thinking about switching to the Autolite coppers.
I was getting blowout after 16 psi dropped the gaps and it was fine at 20 until I did a few sustained high speed pulls and it developed a high speed miss I think was the fine tip glow plugging.
Glow plugging can cause pre-detonation as well...is that correct IJ?
IJ. said:
JDub: Pre-Ignition yes correct !
Swapped em out for same heat range Coppers same gap and it was fine to 7700 sustained
What heat range are you using and gap? Think I've got a project to do tomorrow ;)
