Interesting thought / idea about the block deck
MDCmotorsports
Indy 500
www.MDCmotorsports.com
So I was contemplating the other day.
If you were to have a metal to metal epoxy, something oh say like jb weld...
And it was made to handle high temps oh say like cyl head temps...
And if your block wasn't quite smooth and had some pitting in it....
You could fill the pitted areas, sand smooth and install head gasket.
Surely this wouldn't be for a HP car, but what about the automotive quick fix world?
Yes no, maybe so? Discuss.
Oh, and its not on the market yet - I own the idea. Just look at the time stamp.
:biglaugh:
thedave925
Since 9/16/05
Nov 9, 2005
626
East Bay, Cali
You'd still have to lap the deck for a flat surface, after such a repair. Check this out about epoxies: you can't have air pockets in epoxy at locations prone to heat. So if the epoxy could be anaerobic, it wouldn't matter.
I learned about air pockets through my review mirror on my van. I had air pockets in the mating surface between the mirror mount and window. This supposed 2200 psi epoxy could take the beating of some means subs, but not the heat from the sun. It lasted 2 days.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
He's talking about JB weld or a similar deal though. That stuff should be tougher than what your thinking of right?
I suppose it would work. What temps are jb weld good too? Does anyone make a high temp equivilant of JBweld?
8,898
:biglaugh:
See Fel-Pro MLS Permatorque
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
i actually already did this but w/ epoxy... i'm not claiming the idea, just saying, i had a jdm motor w/ pits on the block deck... after all, i'm on the "keep it running till i'm out of college" motor, not aiming for any high hp #'s
lagged
1991 1JZ
new rochelle
if youre going to go through all that trouble, and since youll be sanding the block deck youll still have to have the motor out of the car and disassembled, you might as well just drop it off at the machine shop to get cut.
any machine shop with MODERN equipment can get a very good finish.
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
when you're 17, in high school, getting paid 6.25 an hour... all of that little stuff adds up, you gotta cut corners in order to make ends meet
suprarich
Guest
Nov 9, 2005
2,187
ohio
This has already been talked about in another thread. I have used loctite 620 with great results many years ago to fix pitting.
MDCmotorsports
Indy 500
Im talking about a quick fix fill and sand high temp epoxy for an auto shop on the local moms mini van that doesn't want to have the engine pulled and wait 4 months worth of labor for a complete rebuild.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Exactly, loctite 620, spread it accross the pitting, add the headgasket and bolt it down. Done! You can also use a titanium caulking and sand that. It is used to repair scratches in hyd. cylinders. I used loctite 620 as the headgasket only on a Nitromethane motor repeatedly and never blew the seal.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
yes jb weld will work if that is the qestion you are asking and will work for year's to come
but you have to buyt eh good jb weld
spoolint78
Representing T.O
T.O
yes jb weld works
We did it on my brothers mk3.
The block had a big pit in it from trying to scrap the stock gasket off.
We just used jb weld and let it dry, then sanded it.
It held 400rwhp all day.
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
I say it depends on where the pitting is. If it's on a fire ring.. no way that'll work with combustion temperatures. If the pitting is near a cooling jacket, then put a dab of high temp permatex on hte pitting, slap a gasket on it, and bolt the head down. Obvoulsy... you can't complain about a BHG if you go with the cheap repair.
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I've seen it done with JB weld more than once with no problems, the toyota 4 runners with the 3vze that blew head gaskets all the time, fill the pitting on the deck, scrape it level with a razor blade, use permatex hi tack or copper spray on head gasket. Used it on 7m head for pitting around coolant ports also.
