Interesting Stuff about Motul RBF 600
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
I just spoke with the People over at Motul. Basically found this out; The stuff in the bottles is packed with Nitrogen and has a shelf life of about 2 years. Adversly so this stuff is not some watered down version of the original that was used for the 24 hour LeMans it is the exact same stuff that the Race cars use.
Basically what i am saying is even though it has gone a bit dark unless you are using your car for some serious track use, you don't have to worry about this fluid breaking down on you to much or boiling over, It is very robust and if i can get some technical data on this i will.
Thus far it is just hear say from what the people over at Motul have to say about there products, but at the same time it is a safety thing and i do not believe they would mention that with use use i am doing and most people do that it is OK, if it was not.
Just my $0.02
mkIIIman089
Ohio
...many race teams buy the stuff at the same places the general public do.
Why would you think it was less then what race teams use?
bobiseverywhere
bobb'n for money
Montreal
The RBF600 is a DOT4 and is not a Silcone based Fluid just so you know also,
I am not to sure about what MDC said, but at the same time i have no prrof one way of the other. :)
Wrll i know my Fluid is older then two years, i just hate pumping the brakes and flushing the system :(
mkIIIman089
Ohio
The downside to vac bleeding setups is that if there are any air leaks around the bleeder itself it will constantly be drawing air in. You could bleed forever and it would still look full of air.
Pumping is still the best way to ensure all the air is out IMO.
I started using the Mityvac when Silicone fluids first became popular here as pumping would just aerate the fluid badly causing a spongy pedal.
I've continued to use it as it means I can change fluids/work on the brakes without needing a helper.
