where does a FP sensor need to be installed to get stable and accurate readings. I am using a AEM ecu and currently have the pressure sensor installed just after the stock junction under the intake manifold. From here the fuel line continues to the rail. then the fuel line comes out of the other end of the rail and to the AFPR. there is a mechanical gauge in the AFPR to set fuel pressure.
The aem displays the FP but it is a bit choppy and jumps around a bit. I dont know if this is from FP pulsations from the injectors going off (720s) or the walbro varying around to fuel needs.
Would it be better to T off the afpr and put the sensor with the mechanical gauge or would that just monitor what the regulator is putting out and not what the fp actually is in the rail?
thanks,
hal
thanks,
hal
