bwest;618565 said:on the back of the block, under the exhaust manifold, there is a 3/8bspt plug that is in a water jacket. get a 3/8bspt > 1/8npt adapter (most senders are 1/8npt), drop it an you should be fine.
you'll probably have to go to an actual hose shop to find that fitting.
Anyone know what this BSPT, NPT (national pipe thread?) stuff is in mm's or even inches would help...I found this thread after a search here, then have done some googling... but =/.
I read this in a thread as I want to install my temp sender and I'm lost as to what 3/8 bspt? is... 3/8 of an inch? and what 1/8 npt is... I get the whole adapter part...
Also what would be the process for installing this temp sender assuming I have the adaptor as wouldn't there be fluid gushing everywhere unless you drain it first? All help would be much appreciated guys.
