Installed Momo steering wheel, can't get horn to work.
SWD Fredester 3
674
baltimore maryland
ForcedInduction;1045813 said:
My Supra was originally an air bag model so there are no contacts on the column for ground. How did you guys get your horns to work?
Double check the connection in the Momo steering wheel hub. Mine had a
ring that fit inside to connect the wire as I remember. I also remember
having to work with the connection, check the point where the wire is
soldered to the ring. Wish I could remember more, its been about 6
years since I put mine on. If I have time tomorrow I'll take my wheel off the
hub and pull the retaining nut to see what I did; then I can get back to you
with better info.
Fred
HommerSimpson
1,067
New Smyrna Beach Florida
with better info.
Fred
what did you do with the cruise stuf ?
SWD Fredester 3
674
baltimore maryland
I eliminated my cruise control, never used it very much. Also removed the unit from
the engine bay and stored everything in case I ever wanted to go back to stock.
ForcedInduction
125
Chicopee, MA
I don't use cruise control much and mine didn't work anyway, so I eliminated it also.
Anyway this is how my column looks like, I know the non air-bag models have a metal contact plate around the clock spring.
This is how my horn button and metal retainer are hooked up. Is it hooked up the right way?
This is how the back of my hub looks like.
