Installed exhaust, interesting symptoms.
TheAmazingDave
Formerly 86mister2
Feb 26, 2007
96
Cali South Bay
Sweet. 500 hp is WAY past my goals. :)
On a side note, I think what I'm experiencing with the transmission is the torque converter transitioning to full lock. The power is definately making it to the ground, so I don't think it's slipping, maybe I'm just paranoid again.
Still doing a fluid flush, didn't have time tonight.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
theKnifeArtist said:
what does that mean..because i've gotten that.
yeah and my auto slips from 1st to 2nd..it sucks big nuts. it makes my rear end swing out all the time.
also..3" downpipe and 3.5" catback? isnt the dp bottlenecking the 3.5" catback? someone explain please, thanks.
Hold your horses, I'm usually not on after 5:00 pm central time ;). When I said choppy I was checking to see if he was having a spark plug blowing out at higher RPM's/boost, leading me to think that if it was, he would want to try and close the gap on the plugs a little bit, or replace them if they are worn. Or it could have been another problem with the ignition system.
Also. a 3" downpipe/testpipe going into a 3.5" catback is not an bottle neck, it's actually a good idea. As the exhaust gases get farther away from the engine, they cool down, cooler gases expand, and the majority of exhaust gas coming out of your tailpipe travels through the pipe on the edges of the pipe, not through the middle of it. Going with an increasing exhaust size setup will decrease backpressure and speed up the exhaust exiting your system. So theoretically (sp?) a 3" downpipe w/integrated elbow, into a 3.5" testpipe (or 3.25") then into a 4" catback (or 3.5" if you do the 3.25" testpipe) would be a most optimal setup ;). Make sense?
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
why would the exhaust expand as it was cooling?
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
BorHor said:
It is the gases that expand.
Gases contract as they cool, or an internal combustion engine wouldn't work being as the rapid expansion of the gas when it ignites is what forces the piston down the cylinder.
