I hooked up a SAFC I apexi to the air flow meter signal on the ecu with the pink and orange wires coming from the apexi to the spot it specifies I cut the wires connected it now the car starts and idles fine, but when I press the gas it won't rev up it just wants to stall. So i reconnected the air flow meter wire to stock and it worked fine again what's causing this problem for me I have an 89 Grey plug ECU, Turbo.
