Install is300 coil packs on 7mgte
walkertx2008
Vivian is a bad Bitch
Oct 1, 2008
164
Robins Air Force Base, GA
Hey guys I got the is300 coil packs to put on my 7m but they didn't come with the wiring harness or clips and I have no idea how to install them, I've searched around and can't find any solid info on a proper install, and if any one has the clips so I can make my own harness it would be greatly appreciated, as would any and all advice on the subject would be awesome along with pictures, thanks guys
walkertx2008
Oct 1, 2008
164
So aside from where the coil packs go what plugs do the wires go on? From the coils? And if I don't have the clips which wires do I soder to the factory clip? And this install will work with out changing the other electronics?
Grandavi
2,663
Calgary, Alberta, Canada
From what I understood (and I may be 100% incorrect) you wouldn't really bother doing this unless you were going to sequential firing order instead of wasted spark. That would require a stand alone to control it.
Bmettie
188
Florida
that setup is wasted spark.
search for 1jz/2jz injector clips and you'll find them. Basically you need to extended the factory harness to reach the new coils positions. I did this and made a new harness using connectors from eastern beaver. Coils go on 2/3/6 with the wires running to 2-5/3-4/6-1.
