Inspecting control arm balljoints
Scott 88-1JZ
122
California
Hi all,
I am currently installing poly bushings through out my control arms rear first then the front. I have a question regarding inspecting the ball joints (upper control arm). What is the proper procedure for checking the turning torque. I followed this from the TSRM.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=RA&P=67
note: my 92 manual I own states 9-30 ft-lbs. that is quite a typo:nono:
Can someone clarify when the ball joint is bad? I am taking this spec to read that the ball joint should not take more than 30 in-lbs of torque to turn. Also the boot oozes out some grease out of the top as you move the stud back and forth. I think that when the joint is torqued down it would seal against the face of the arm. is that right?
supra90turbo
shaeff is FTMFW!
MA, 01440
Thread the nut onto the control arm until it bottoms out(only finger-tighten it)
With the arm upside down, stud facing up as shown in pic, using a gauge type torque wrench <HERE>
Measure the amount of torque it takes to turn the nut, which, in turn, will turn the ball joint inside the socket. If it spins less than 9 in/lbs of resistance, it must be replaced.
Scott 88-1JZ
122
California
Thanks for the reply. In my ongoing search I also came accross this page. Which is a tech update I believe. It differs from the service manual where it says 31 in-lbs or less.
http://www.toyotapart.com/SUSPENSION_BALL_JOINT_INSPECTION_T-PG027-02.pdf
I have tessted most of the arms and there is no vertical free play felt and the torque seems to be in the range of 10-15 in-lbs. I am hoping this is good and now just kinda of seeking conformation to my above assumption that less than 31 in-lbs of torque to actually turn the ball joint means its good.
