So we checked again with a noid light and the injectors are getting power but not very much you can only see the noid light work if the lights are off in the garage and it lights up very dim
jetjock;1974892 said:It was neither but here's hoping you still learned something. I'm guessing Dirgle did.
7M4EVR;1974989 said:This^
Kinda pisses me off because there are some of us that come in that actually appreciate the help and check the things we're told to check and rule them out. I just now put two and two together from his new thread with the same problems that he previously solved by the neg battery cable or bad ground at tailshaft of tranny:
http://www.supramania.com/forums/showthread.php?188067-89-7mgte-runs-rough-no-throttle-response
