Injectors won't pulse not getting power
Dirgle
Conjurer of Boost
Pauma Valley, CA
If they are lighting up, they are firing. During cranking the pulse width is very very short. So the noid light does not get the chance to get very bright. You mentioned that you tested for fuel pressure. What pressure did you have? With Fp and +B jumpered and the ignition on you should have 33-40psi.
Oct 11, 2005
3,821
26
Thousand Oaks, CA
Don't waste your time with the TPS. That person is talking nonsense.
If you think you have a weak injector supply, jumper 12V from the battery to the brown wire at the injector resistor pack on the driver side fender. Make sure your jumper wire has a 15A fuse.
Backyardmechanic1
31
Happy valley oregon
I did that nothing changed there is a plug on the drivers side fender I can't figure out what it goes to its right in between the diag box and the resistor any idea what it goes to or if it has anything to do with injectors it's yellowish white and has 4 pins
Dirgle
Conjurer of Boost
Pauma Valley, CA
Depending on which theme you are using the colors might be different, but the buttons are the same.
First:
Next:
This will open a box that will allow you to select pictures from your computer.
Dirgle
Conjurer of Boost
Pauma Valley, CA
That would be the connector for the Headlight Cleaner Relay. It's not tied into the engine management systems, so nothing to worry about.
Backyardmechanic1
31
Happy valley oregon
I got it running I believe it was either the connection to the block on the negative battery cable or a bad ground at the tail shaft of the tranny thank you to everyone that gave advice and helped me out
7M4EVR
695
fah, fah away
jetjock;1974892 said:
It was neither but here's hoping you still learned something. I'm guessing Dirgle did.
This^
Kinda pisses me off because there are some of us that come in that actually appreciate the help and check the things we're told to check and rule them out. I just now put two and two together from his new thread with the same problems that he previously solved by the neg battery cable or bad ground at tailshaft of tranny:
http://www.supramania.com/forums/showthread.php?188067-89-7mgte-runs-rough-no-throttle-response
8,897
7M4EVR;1974989 said:
This^
After reading the other thread, no. There is no injection, as mentioned in this thread, with out the STA signal, and after that Ne and Ks.
