In the middle a refurb of the engine body harness and engine harness. The connectors I'm heavily considering for the body to engine harness plugs can take 20 amps. From my research I've concluded that the injectors CAN draw as much as 4-6 amps each. The only hold up is the power to the injector resistor. Stock uses a .250 series with a 14g wire.. Its a rather large terminal and the largest wire in the engine harness.
Is it as simple as multiplying 4-6amp x 6? or is my info bad on the current the injectors require? if its that simple I'll move to a different connector..
I have the tools to measure the current, just not a running car due to a jump start on the harness tear down.. any body with the knowledge care to enlighten me?
---------- Post added at 12:22 AM ---------- Previous post was at 12:18 AM ----------
I know all 6 never fire at once, but the heat build up from the engine cycles + the near constant current draw to the resistor may be enough to warrant a larger connector. I also understand that the initial opening is where the load is at, and current should drop off quickly. Trying to make an evidence based decision, not an assumption.. Jetjock or jdub care to set me straight?
