injectctors wont pop
YUNGPIE
17
BAKERSFIELD CALI
dont know car dosent even turn on
---------- Post added at 10:41 PM ---------- Previous post was at 10:35 PM ----------
thanks 4 the link that will come in handy dont have no money 4 a mechanic or i would have done that, is merced far from bakersfield?
Txsupra
Professional Driver
Aug 23, 2008
239
Texas
What computer are you running, factory? If so what year is your car? Is it an automatic? When was the last time it ran(What was the last thing you touched before it stopped)?
YUNGPIE
17
BAKERSFIELD CALI
Its a factory ECU MT IT RAN DURING THE WINTER TIME SO NOT THAT LONG AGO the turbo blew along with the head gasket took the head to the shop 4 a resurface and new valvestem seals put a toyota head gasket in with a new unclipped harness got in and cranked her she just turns over and over gets spark no fuel i can make the injectors open if i ground them out so i know the injectors work so wat do you have in mind? i put the other harness back on and does the same thing. will it not turn on if the TPS is not working?
