ijz tranny swap
thunder_nick
77
Marquis Sask
Okay this may sound like a stupid ques but whenever i search it i get lots of things but only a few about the swap..
I am pretty new to the supra world so if the ques sound stupid sorry ha ha..
I can get my hands on a 7m from an accident.. its a 5spd.. I have a ijz and was wondering if that tranny will work in my car and what else i could use from that car and what all i would have to find else were.. thanks alot
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
im guessing youve got a JZA70, and your tranny is on its way out? THe bell housing is different, but you can get one on here. Other than that the tranny will work, same clutch and everything
thunder_nick
77
Marquis Sask
yea my tranny is starting to slip.. and its not that often its like once in a day if that.. but still if I wait till it is totally gone I will be shit out of luck
thanks for your help just hope this guy will still sell me the car would love to get this done sooner then later..
what kind of bellhousing will I need then???
Jayhall
May 7, 2005
1,167
Surrey BC
the tranny is slipping? are you sure its not just your clutch?? If you end up with the car, youll need a 1JZ bellhousing, its a genuine toyota part, should cost around $359 new if i remember correctly.
bluemkiii
redmkiii's little brother
Jul 25, 2007
729
phoenix, AZ
But he has a 1jz already so all he would need to do is take the bellhousing off the excisting tranny that he has on the car. And bolt it up to 7m tranny. Also OP you didn't mention if the 7m was na. They come with different trannys(w58) that aren't as strong as the turbo models(r154).
Also as mentioned above make sure its not your clutch.
Jayhall
May 7, 2005
1,167
Surrey BC
now that you say it, it seems so obvious. Most definatly, why waste the money.
Jayhall
May 7, 2005
1,167
Surrey BC
no, an automatic does not have a clutch. It would have a tourqe converter.
Both JZA70's (jdm) and MA70 (usdm, TURBO) us an R154 transmission, so yes it will bolt right on, so long as you take the 7M bellhousing off first :p
thunder_nick
77
Marquis Sask
okay i should be able to figure that out.. so now the guy i wanted to buy the car off of isnt a turbo or standard ppl lie damn.. so i am going to buy everything myself.. so waht all am I going to need for it?? if you could help wit that it would be great..
*edit* forgot to mention that my car now is an automatic...
Jayhall
May 7, 2005
1,167
Surrey BC
oh so your looking to do a 5 speed swap. Ive never done one, but the search function on this forums works wonders. Many other members have done the swap. Im not sure how many have done it on a JZA70. Dont hold me to this, but as i recall, ive seen members selling a "5 speed swap" which includes pedels, and everything eles you would need
Its too bad, I had a JZA70 that i used for a parts car, and i would have had EVERYTHING that you will be needing. But, like i said, use the search and you will find all the anwsers your looking for.
Jayhall
May 7, 2005
1,167
Surrey BC
yes a 6 speed from a mkiv would work. But your looking at about $3500 US to buy the tranny itself, and thats used.
thunder_nick
77
Marquis Sask
Yea thats what I figured ... so since my car is an auto would my bellhousing still work with a r154?? would I have to make new mounts to hold the trans or will it just bolt into to the auto ones?? thanks again for the help man its greatly appreciated..
Jayhall
May 7, 2005
1,167
Surrey BC
i dont think the auto trannys have a bellhousing. To do the 5 speed swap, youll need a R-154 from a JZA70 or buy a R-154 from a MA70 and 1JZ bellhousing
thunder_nick
77
Marquis Sask
I am swapping my tranny in my 92 ijz rhd supra.. its an auto now and going to 5spd.. can some one push me in the right direction of a thread of someone doing this? i have searched and cant come up with it..
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
would a rhd shift pattern be the mirror of a lhd shift pattern? reading from left to right, top to bottom: lhd: 1-3-5 - 2-4-R, rhd: 5-3-1 - R-4-2?
JonoTurbo
Going for broke
CT
Heh, its the same.
To answer your question though. you'll need:
flywheel and bell housing for a 1jz r154
7m or 1jz clutch kit
master and slave cylinder and the lines
r154 driveshaft
clutch pedal and matching brake pedal
You will have to jump the neutral start switch on the auto transmission harness as well, but otherwise your ECU and harness will work fine with a 5spd.
On lhd supras, the firewall is actually perforated in the spot where the pedal and master cyl mount, so this may also be true for rhd cars. You will probably need a pedal set from a rhd car, and a longer clutch line than the lhd supra has too.
Sorry I can't help you with a thread at the moment, any threads out there are probably for lhd cars anyhow.
thunder_nick
77
Marquis Sask
JonoTurbo;1165740 said:
Heh, its the same.
r154 driveshaft
thanks for your quick reply man
I have the guy in bc he has the tranny clutch flywheel bellhousing and everything all for 1300 shipped to my door thats not bad considering buying it all sep would have put me over 2 grand.. someone also told me that because my car is the rhd ijz with the jza70 that the shaft is already the long one that I need. i may be wrong if i am can someone correct me..:D
