Idle valve for the Stinger...
rakkasan
Currahee!!
Fort Campbell, KY
bigaaron;922405 said:
I had shipped the same one to Mark a month before that and it got rejected and sent back! :(
I didn't reject it, the apartment complex i lived in did. Since I had moved a month before you sent it, they sent it back. I'm pissed about it too, I've NEEDED this all winter.
Have you had any feedback for the guy you had sent it to?
bigaaron
4,692
Pomona, CA
www.driftmotion.com
You said you were going to order the Wolo one like 2 months ago :1zhelp: :biglaugh:
rakkasan
Currahee!!
Fort Campbell, KY
I did, but I haven't had time to get it done regardless. I still have targa seals, HID's, power steering pump, whiteline sway bars, speakers, iridium plugs, and a ton of other brand new parts sitting in my garage because I can't find the time to install them.
This is one of those thing that I would have to find a way to get done....
bigaaron
4,692
Pomona, CA
www.driftmotion.com
That's whats great about Supramania, people coming up with cool new ideas and helping each other out.
One thing I was thinking, is that you could use two Stinger outputs to control the valve, one that is RPM triggered, and one that is coolant temp triggered. That way it will always fast idle when cold, but also fast idle when you have heat soak.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Thats what I wanted to do, but now I have
1)fuel pump
2)idle valve
3)meth injection
4)tach output
time to upgrade to the 8860
Aaron, I don't have a valve that you sent. I don't remember talking with you about one either, but then again, I'm on medication. I do need to install one though so my car will crank better when it's cold.
Mark: Got ya!
Might be an idea to contact one of the Stinger engineers and see if they can implement 3d tables for all the Aux outputs it opens up so much scope in setup!
Most companies are only to happy to work with customers to improve their product and add wanted features.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Thats a great idea IJ. They have 2D options, such as RPM & Boost dependant aux outputs, but none for RPM & Temp :(. I can't imagine it would be impossible to get it incorporated in an update.
gravesdu_99
255
Potsdam
I know that this an old thread, and thats why all the ebay links are dead. Can somebody show me a new link to what you guys are using. Also it looks as this is a simply two wire device. So why can't the idle speed control option be used with this.
