Idle issue on fresh rebuild
mattmann
33
maryland
So after my baby being dead for 5 years i finally got the done and installed. I have all new everything on the inside of the motor -eagle rodes, probe pistons, cleveits, driftmotion's uprgrade oil pump, bc stage 2 cams, obx underdrive crank pully and titan adjustible cam gears. The motor turns over and starts fine, under its own power it runs great to... however it does not like to hold an idle. I have checked and redone the timeing twice, tonight being the second and now it will hold an idle sometimes and others when i thow it in neutral it jus dies??? i have also tested all sensors on the motor ics(valve), tps, verious water temp sensors, cleaned and double checked grounds and vacume lines. ALSO this was a jdm motor so no egr and my machinest had to deck the hell out of it so i have a 2mm stopper hdg not that that matters lol... if anyone has any advice i thank you in advance.
Check your codes. Even if there is no light.
Also id take that obx crank pulley off asap unless you like ruining your front main bearings,.
mattmann
33
maryland
The only code i have is the one for the speedo gauge and thats only becuase it decided to fall apart yesterday, is that crank pully really that bad? Either way im gonna junk it, ive got way to much money in it to wast it lol
Yes. It doesnt provide any dampning. Get a ati if you want an upgraded dampner.
Did you set the ign timing to 10*? Cam and crank timing good?
mattmann
33
maryland
I sure did, i put the motor to top dead center and the at idle adjusted the cps so the motor was running 650 rpm at 10* with the service wire in and so on... lol. Im thinken it could be that crank pully, or mabey a bad injecter... ugh damn cars
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
78
Atlanta
Are the cams timed properly?
I recently put a motor together, and after I was positive that both cams were dead perfect, I took the cam cover off and found the intake off by a tooth.
mattmann
33
maryland
My cam cover is off and the seem to be dead on, im gonna put the stock crank pulley this weekend n see if that helps at all. thanks for the help guys, i will post if i have any problems after that.
mattmann
33
maryland
The factory crank pulley is on, the timimg is as good as its gonna get because it seems to jump around a little like its missing but i just did a spark check and all cylinders are firing. When i say the timing is jumping around i mean it doesnt want to stay at 10* but goes back and forth from 9 to 12 and the car is very rough when it does idle. Does anyone have any ideas im abought to replace all vacume lines on the motor, its driving me crazy lol
