The TPS has two functions:
1) Signal the ECU when the TB plate is closed (IDL)
2) Determine TB plate opening angle to the ECU (VTA)
IDL is a simple switch...it's open or it's closed. Closed puts the ECU in idle mode. The ECU works on voltage not resistance...in the case of the TPS, 5 volts is supplied to Vc in the diagram (link below). Think of VTA as a volume control knob on a radio, as it moves higher on the scale, voltage increases. Voltage should vary between .1 to 4.2 volts as the TPS is rotated to full open.
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=FI&P=101
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=FI&P=103
You might want to check VTA at the ECU to see what voltage is present. The TSRM outlines how to do it here and on the following pages:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=FI&P=50
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=FI&P=51
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=FI&P=55
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=FI&P=56
(pay attention...you do not want to short the wrong terminals at the ECU)
ISCV inspection:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=FI&P=107
Note how you can get the ISCV to move by grounding the appropriate terminals.
Here's how to test the fuel cut RPM:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=FI&P=125
It occurs at 1600 RPM, not 3000. Basically the RPM should bounce between 1200-1600 RPM with IDL & E2 connected and the gas slowly advanced.
A couple things to check:
- Make sure the TB plate is full closed with the engine at idle.
- Since this is an '87, check the air bypass screw on top of the TB. It should be fully closed (screwed in). It is set that way from the factory, guys mess with it and cause all kind of problems.
- Block all air at the ISCV inlet from the accordion hose (plug the hose). The engine should die.
ISCV inspection:
