IC Q's
8T7supra
78
New York
when is it necessary to upgrade you IC. i am getting a bigger turbo and was just wondering if you needed to upgrade you IC fro it.
silvergsx623
WIPLSH & HWY KNG
Oct 16, 2005
498
Alabama
I've see supra guys do 400+ on stock intercooler pipes and intercooler. However a good designed intercooler will yeld more power than stock.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
an aftermarket IC on stock boost levels is not going to get you much of anything. If you're running say an aftermarket turbo, or the stock turbo much past stock boost levels, then a new IC would probably be a good idea.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
An aftermarket one is more efficient. It will create cooler air going into your cylinders. You can get an intercooler and piping kit for probably $300 off ebay. Plus an aftermarket one looks sweeter chillin behind the bumper. Just my 2 cents though.
Piratetip
Far From Maddening Crowds
1,179
70
MKE, WI
Replacing the restrictive IC piping would be a better option. Later down the road then the IC if desired, drop temp a few degrees.
BJ91T
810
Baton Rouge LA
Ic is not a big need at first it will cool the ct 26's charge so when you upgrade the turbo your charge is actually cooler due to the bigger turbo making the same boost that your stock turbo did but doing it with less work
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
May also be worthwhile to note the condition of the stock IC... if the cooling fins have been beaten to hell by rocks, it might not be a bad idea to replace it. If it's in good shape, refer to above.
