Ic piping setup hate or love
what do you think
  • I like
    Votes: 11 11.1%
  • don't mind
    Votes: 35 35.4%
  • don't like
    Votes: 53 53.5%
  • Total voters
    99
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well i have some issue with my ic piping and well i found a way to run it staight as possible but it's kinda odd and not really comon well for a mk3
i chould clock it faceing toword the vavle cover but i amjust incressing leagth and find even more odd
now if clock it down with point stright alot of my power streeing junk is in the way witch is gay again more bends more leagth
note the trubo will have the cupler section chopped off so the hood will clear so it will sit lower down
so what you guys think ?
NEW setup little more piping diffent look not in pool
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
aesthetically speaking it is much better looking with the turbo clocked pointing downward. If you like it this way and you have found it to be shorter and straighter then I say go for it, but I would probably clock the turbo the other way because there is probably a pretty marginal difference in performance between the two setups.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
if it were that easy i whould
to much stuff in the way to make it stright my oil lines are just tad in the way and my ic end take it just not in good area to start form
i worked it out i gain about littel over 1 1/2 feet extra and shit load of shitty bends
now if was to relocate alot of my powerstreering stuff it healp out alot
but alot of money to do it the way i whould do it
so i cna leav it as is or chnage it
i not a fan of it as of now but kinda growing on me mabye is the money thing that is growing on me
supraguru05
Offical SM Expert: Suspension & Vehicle Dynamic
Dec 16, 2005
737
louisville ky
more interested in your crankcase vent system. do you have a exhaust exit along with the vacuum from the manifold with a check valve preventing boost from entering the system. at least thats what it looks like to me
johnd
278
Ont. CA.
:aigo: :biglaugh:....... Try running it along the frame rail 45 down under the rad 90+180 and your there.
Nice clean engine bay though!
dumbo
1,912
Albera, Too Far North
the less the bends the better, shorter lengths help but not as much as bends.
IMO. would it be hotter up there though?? cutting the compressor up, are you gonna disassemble it first??
NashMan
Aug 5, 2005
4,940
17
Victoria BC
power streeing junk is there or that is what i whould do or i just relocated it
thanks thou
dude what do you think :rolleyes:
heat not really an issue i have big eghough of inter cooler so that is not an issue
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well after some reseach i find i can do it 2 wasy thus why i made the te there
into intake pipe
and for exhuast i will run it to my waste gate dump cause the main dp will jut not work as good as the waste gate pipe
still up in the air what i wana do for that right now
dumbo
1,912
haha just making sure, I like it, painted i think it'll look fine, as long as you can get her to clear the hood.
is that 3inch?
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
I would think that first hard 90 would impose as much of a restriction as the extra 1 & 1/2 feet of piping with a few more but milder bends. The second bend that drops down to the IC looks sharp as well, and I can imagine the sweep to the IC inlet is also a pretty tight radius. I know one hard 90 is the equivalent of 20 feet of tubing restriction wise, now this is when dealing with fluids and your bend do have a bit of a sweep to them. Form>Function always but in this case it seems this rout might not be optimum. We arent there with the set up in front of us so its hard for us to really judge. I personally would take a few more feet over sharper bends but I trust you'll find a way to determin most efficient way Ryan.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
if i go the other way it like 2 sharp 90's and some but off the compress it's not that bad since heat will help it's comon thing to see a 90 off the trubo
but another note is if i have any issue wiht piping poping poff it's an easy fix on the side of the road that is one plus to all this
plus i only have one bad bend that is all rest are like mabey 15 if that
ps this is just a pipe i had lyinh around to test with for looks
egay manfold are only do so good i wish i had the money to make one from scartch
