I think I figured out why I can't BHG.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Thought the base timing might have been off, so I broke out the timing gun.
Sure enough, for some reason base timing was sitting at 0 degrees. :1zhelp:
:D So I bumped it back to about 10ish...
I think I'll BHG within the next 200mi.
I haven't test driven it hard yet, but what kind of power difference can you make from 0 degrees base timing to 10 degrees? :rofl:
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
My stock gasket is holding up good, 13psi for 18 months now.
If you think your timing is retarded I set mine when I put my car back together as per TSRM must have moved a tooth as I put the CPS back in, car was flat as a fart. Put the timing gun on it 10* after tdc:nono:
MK3Brent
Very expensive....
Aug 1, 2005
2,878
I used to run 15 with C16 back in the day with no real benefit... but that was like 20psi on a upgraded CT.
I've done numerous 20+psi pulls on the GT4088 now with a toyota HG toyota bolts at 72ft/lbs.
We'll see! :)
Brady
266
Bay Area
www.nbhq.net
stock bolts? ARPS what are you torques to?
