I have an engine that bent a rod, however I have another block that was in working condition before it got handled by a shop and seperated from the head(don't ask). I use my supra as daily trasportation so I am in need of fixing it. My plan is to get my old block and use my working head from the broken engine. I have a few questions. One is that, is there anything I need to look out for as far as the timing belt goes? I mean as far is that is concerned should I just follow the TSRM? Also for the headgasket, do I really need to find out what MM size I need to use? Say if the issue is the valve clearence, what are the consequences if I were to just put the thickest head gasket that HKS makes, will that effect or harm it in anyway besides raiseing compression? I am doing this as quick as possible and learning as I go and am open to what you guys have to say since you guys have helped me alot in the past, and I thank you all. I am probably going to do the front and rear seals on the engine since it is out as well as the oil pan. On a side note i know this car is expensive but i like it and i am sticking to it lol.
89 turbo targa supra 5spd
-Steve Z
P.S. I know I don't know that much but thanks for dealing with me.
-Steve Z
